Hypermesh input file to Abaqus CAE solver
Hi there,
I am new user to Hypermesh. I want to open input files from Hypermesh in Abaqus CAE to modify and add more parts to the assembly. Is it possible to do that? I have here the input files generated in Hypermesh. However, after i imported in Abaqus, nothing appears in Abaqus CAE. Anyone had the experience before?
Any ideas to open it.
http://files.engineering.com/getfile.aspx?folder=9...
RE: Hypermesh input file to Abaqus CAE solver
The message area at the bottom at CAE tells you why the data are not imported.
Workaround: Run a datacheck and use the .pes file.
Hi Mustaine3;
I dont know, i even cannot run the data check.
