2205 Heat Exchanger Tubesheet
If I have a shell and tube heat exchanger that has a non-welded (TEMA Type BEU) 2205 Duplex tubesheet, is impact testing required if the tubesheets is 1 1/2" thk?
Thanks!
RE: 2205 Heat Exchanger Tubesheet
Most likely, see UHA-51(d)(3)(a). What is the MDMT?
Mike
-20f
-20 F & over 3/8" thk, you are impact testing.
Mike
