Measure bodies distance
I need a macro to do the following. I have two bodies located in 2 different parts, that I need to measure the distance between both.
How can I do it? I only have four days examples for parts.
I'm doing in vb.net, but you can help me in the other languages.
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
RE: Measure bodies distance
Found it.
CODE --> CATVBA
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
'Two bodies are already selected
Set selection1 = partDocument1.Selection
Dim a As Body
Dim b As Body
Set a = selection1.Item(1).Value
Set b = selection1.Item(2).Value
Dim reference1 As Reference
    Set reference1 = part1.CreateReferenceFromObject(a)
    Dim reference2 As Reference
    Set reference2 = part1.CreateReferenceFromObject(b)
'get the SPAworkbench
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
Dim TheMeasurable As Measurable
Set TheMeasurable = TheSPAWorkbench.GetMeasurable(reference1)
Dim MinimumDistance As Double
MinimumDistance = TheMeasurable.GetMinimumDistance(reference2)
End Sub
Tiago Figueiredo
Tooling Engineer
Youtube channel:
There is always a good reason for something :)
But i don't have the need to export it. It's something that I need during a macro execution, Depending in the value of the measure it does some actions.
Tiago Figueiredo
Tooling Engineer
Youtube channel:
