Using a turbulence model in a numerical wake modeling technique
If I were to model the wake of a wind turbine using a certain numerical method should I, or should I not, take into consideration a turbulence model and couple it with the numerical method being implemented? It would be helpful to know the reasoning behind your explanations too.
Thanks in advance.
vktsn0303
RE: Using a turbulence model in a numerical wake modeling technique
From NREL (NATIONAL RENEWABLE ENERGY LABORATORY)
Wind Turbine Modeling for
Computational Fluid Dynamics
December 2010 — December 2012
L.A. Martinez Tossas and S. Leonardi
University of Puerto Rico
Mayaguez, Puerto Rico
NREL Technical Monitor: Pat Moriarty
It may help you.
Cheers
