Can Post Heating 300 deg C will help
Hello Expert,
I am having a situation , where i need to do repair welding (including root, in few segment) of 40 mm thick & 400 dia (no inside access) SA 333 Grade 6 seamless pipe.
I am in opinion that repair shall be conducted in following steps,
1. Remove complete defects by grinding,
2. Make V groove
3. Put the insert in required segment and leave small peep hole for root visual inspection.
4. Complete the welding by GTAW +SMAW process.
5. Immediately after completing the welding do post heating for 1 hour at 300 deg C.
6. Do relevant NDE as required in Spec.
7. Do PWHT.
My Question are following
1. IS new WPS/PQR required for this ?
2. Is Post heating at 300 Deg C for one hour will help ?
3. Please suggest if any points need to add.
Any precautions need to take , please suggest ?
The line having 126 mpa pressure and approx 326 degree C temperature as design.
RE: Can Post Heating 300 deg C will help
Why are you performing a post weld bake? Why not use low hydrogen electrodes H4 with the SMAW process? I see no reason for the 300 deg C bake for this material.
Everything else looks fine.
While the dehydrogenation heat treatment will not be detrimental and may prove helpful, as per metengr, it is not warranted and is more costly. A new PQR with the dehy treatment is not required.
