Maximum content of an element in material
This is my first post here.
If an ASTM standard material specifies max content of an element (say 0.5% of molybdenum), then can the content of that element in the material be accepted as zero? Or is it mandatory for some percentage of that element to be present in the material?
RE: Maximum content of an element in material
The material specification doesn't say anything about a element (e.g. Nitrogen), but the received MTC for that material has some percentage of Nitrogen.
Is it still acceptable?
You can look this in a bit wider scope also.
I suggest that you read A751.
You can add unspecified elements for processing reasons, but if they change the grade or properties it is not allowed.
I checked the minimum tensile / yield strengths and elongations of the supplied material (one with additional elements) and it meets the requirements of the material specification.
