why product rotate in Catia assembly when use contact constraint?
Hi
ia have a problem when i set contact constraint on two surface those surface contact But one of them rotate 180deg
how can i choose to rotate piece or not when using contact constraint?
here two picture of my problem
http://files.engineering.com/getfile.aspx?folder=4...
http://files.engineering.com/getfile.aspx?folder=f...
thanks
thanks
RE: why product rotate in Catia assembly when use contact constraint?
for what you want you should use coincidence with same direction
