Bolt tension load approximation
RE: Bolt tension load approximation
Hi guppers
The formula you are asking about isn't a named theorem but its based on the fact the joint is statically indeterminate.
The component parts held by the bolts or screws are assumed to be totally ridged and in order to get round the indeterminacy of the bolts its assumed that we have a load per unit length of the members between the applied load, pivot point and bolt positions.
Have a look at the file I up loaded in the thread you referenced it might help.
Thanks, Desertfox!
This may be a silly question, but which 12" are you using in that file? I wasn't quite sure when I looked at it. Also, did you find this in Bruhn, Peery, or learned it through the course of your career? That is a really helpful trick that should be taught, IMHO.
Hi guppers
In the file the 12" is the distance the external force acts from the pivot, this is balanced by bolts at 10" from the pivot and 2" from the pivot.
First found the formula years ago in a book produced by an engineering union called TASS
This is pretty standard bolt group analysis, no?
