What could be the reason for using
What could be the reason for using SAE 1141 grade steel in Railway engines - parts such as rocker arm and valve bridge? since it has an ideal diameter around 2 inches, is it possible to get martensitic structure at the core in a section 1 1/2 inch diameter and height 2 inches?
RE: What could be the reason for using
