CPA Cubic Plus Association Liquid-Liquid phase equilibria
does Prode Properties require the same BIPs for vapor-liquid and liquid-liquid phase equilibria with CPA Cubic Plus Association ?
RE: CPA Cubic Plus Association Liquid-Liquid phase equilibria
Prode Properties allows to define one BIPs data set per each model (you can define different models for fugacity, enthalpy etc.) and stream,
for a vapor-liquid phase equilibria or a vapor-liquid-liquid phase equilibria normally one gets BIPs from VLE database (which includes a large number of BIPs, I think about 30000 or more),
for liquid-liquid phase equilibria or solid-liquid phase equilibria or hydrates there are specific databases (there are four databases, VLE, LLE, SLE, Hydrates)
to obtain accurate results with liquid-liquid (or solid-liquid or solid-vapor) phase equilibria I calculate the BIPs with the data regression procedure included in Prode, there are examples in the operating manual
http://www.prode.com/docs/pppman.pdf
however, calculated liquid-liquid fractions are different from our reference while vapor-liquid is Ok,
what can I do for calculating the correct vapor-liquid and liquid-liquid fractions ?
See the attached image as example,
Prode can calculate optimized values (for both VLE and LLE)
