can we use the galvanised bolts in the underground flanges of GRE,directly buried in contact with
HI EVERYONE
I would like to have some feed back about on the galvanised bolts in the underground flanges of GRE , for firefighting network new project, directly buried and in contact with soil )may be subject to corrosion or not.
I am just to see the necessity to protect these bolts by some type of coating because they will be in direct contact with soil and to avoid the corrosion potential problem.
Many thanks for your helpfull
From Reggane project
RE: can we use the galvanised bolts in the underground flanges of GRE,directly buried in contact with
https://www.galvanizeit.org/hot-dip-galvanizing/ho...
Many water utilities have standardized with stainless steel for buried water mains. All bolt-up sets (nuts, bolts and washers) and tie rods for buried valves and fittings are stainless steel.
