Need help with calculation...
I am hoping somebody might be able to help me figure this one out.
How many pounds of pressure (PSI) would it take to move seawater with a density 0f 64 lbs CU/FT at a rate of 250,000 gallons per minute?
Not sure how to work this one out, or if I have all of the necassary information.
RE: Need help with calculation...
-What is the elevation change between where you are pumping from and where are you going to
-What is your fluid velocity (you need to know pipe area to calculate this)
Jeff
Pipe Stress Analysis Engineer
www.xceed-eng.com
Dik
https://www.google.com/search?q=energy+equation+fl...
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
