differ between clesd head sprinkler pattern and nozzle spray pattern for the same k factor
Dear Members,
what is the difference between closed head sprinkler pattern and nozzle spray pattern for the same k factor?
my problem is that i have close head sprinkler network installed for a store and the HJ requested to replace this sprinkler by open head nozzle and when i mad a quick check i found this action can be applied,
the contractor said i cannot be replaced by the nozzles , it must replace the pipes ( even it has the same pressure, flow, and velocity?
i need a justification for the contractor?
your respond to my message is appreciated.
RE: differ between clesd head sprinkler pattern and nozzle spray pattern for the same k factor
With open nozzles every nozzle in the system must and shall discharge at the same time. A wet pipe sprinkler system is only designed to have a certain number of sprinklers operate [not less than 5]. Reference NFPA 15.
Nozzles have different spray patterns than standard spray or extended coverage sprinklers. With nozzles you must account for the pressure, angle and k factor along with the density and area to determine the coverage. This shouldn't be an easy swap but an entire overhaul.
my problem with the contractor is the contracotr refuse to change the sprinkler with the same properties nozzles.
I suppose I don't see the need for such a specialized system for mercantile.
R/
Matt
