Pressure Reducing Valve, and Further Reduction of Pressure
I am trying to bypass pump station to service and recoat a 200k gallon storage tank, the total head of the system straight thru the bypass connection would be 824 ft, which is about 357 psi at the bottom of the system, therefore I need to reduce the pressure at the bypass with a pressure reducing valve (PRV).
I checked the pressure at the bypass point and I am looking at 185 psi, if I use the PRV I can reduce to 80 psi without running into cavitation problems (According to the cavitation guide published by the manufacturer)
Now, the problem I am having is that there are still 413 ft (178 psi)of head from there to the bottom of the system which will increase my pressure to (80psi + 178psi = 258psi)
My question is; if I want to reduce pressure at the bypass point lower than 80, can I achieve this by installing an orifice plate just after the PRV?
Thanks, everyone. (Please see attachment)
RE: Pressure Reducing Valve, and Further Reduction of Pressure
--Winston S. Churchill
I found the manufacturer also has anti-cavitation PRV. has anyone used those before?
But, What if to run the flow with the whole hydraulic pressure of 357 psi at the bottom of the hill without the pump running?
