Vibration analysis Help
Hello
I am a mechanical engineering student and i am working on a reducer flender dmgh 25.4 for my final engineering intership .
I got vibration analysis of output shaft on excel data . Siemens haven't yet send the conclusion of those analysis.
Is there anyone who can tell me how can i figure out if there a problem or not and is it possible to make those infos visual on a drawing or something like vibrations schema.
Sorry , i am not so good in english .. i am going to join the excel data on this thread .thank you
RE: Vibration analysis Help
I (or others) could probably do an FFT analysis for you, but that would not be much of a learning experience. Figuring out whether there is a problem or not requires interpreting the vibration waveform and spectrum combined with the machine component details which you have not provided. A basic Internet search on gear vibrations could get you started to learn about vibration analysis and fault diagnostics.
Google Search: crunching ffts with microsoft excel
Walt
