Simulation for Compression Unit
I'm trying to simulate the compression unit regarding to check outer rubber grip part to withstand 60 Mpa
Shaft - Inner Dia 0.55" Outer Dia 0.6" which fit with compression unit and unit screw with 1/4 20 UNC ANSI screw for
compression unit is assemble with shaft grip assembly (Please refer the attached drawing image).
The idea is to fit the shaft inside the rubber grip with compression unit, while maintaining any rubber grip deformation.
Please some help me to setup this Advance Nonlinear simulation by spending some of your valuable time
Thank you,
Buddhika
