Assembly constraining two pins to two holes problem
Hi
When I constrain two pins to to holes say the distance between holes is 100.00000
and the distance between the pins is 100.00001 NX refuse to apply it.
Is there a setting that I can use so the constraint will be applied. (without distance changing)
(for example tolerance control or something else)
Thank you in advanced.
RE: Assembly constraining two pins to two holes problem
Customer Defaults :ASSEMBLIES/POSITIONING/SOLVER..... look for Linear tolerance...not sure but worth trying it i guess.
Kapil
I' thank you very much
yes their are two setting linear tolerance and angular tolerance
But because these setting are on the customer default
I afraid that later when the customer default will be
Changed again I'll have a problem.
Because I know that their are other nx tasks that have the
tolerance directly on the nx task dialogue
-Dave
NX 9, Teamcenter 10
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Actually for years I'm used as John said.
But john you know this for years
what is the rreason that nx not include
the tolerances in the constraints dialogue?
Irvine, CA
Siemens PLM:
UG/NX Museum:
