How to specify nylon heat stabilization?
I have often seen different grades of nylon listed as heat stabilized, but there does not seem to be any performance data to say how effective is the heat stabilization. Is there a standardized way to specify this? I want to add it to one of our company material specs but it doesn't seem adequate to just add the term "heat stabilized" without any criteria.
RE: How to specify nylon heat stabilization?
https://en.wikipedia.org/wiki/Oxidative-induction_....
Start with this link and then search other sites for more in-depth information.
https://www.nist.gov/sites/default/files/documents...
The thing is that there is no simple answer to your question. There are many degradation mechanisms involved and every application has a different sensitivity to material degradation. So there are numerous tests which can be extrapolated in several ways.
EMS Grivory
www.tynevalleyplastics.co.uk
Politicians like to panic, they need activity. It is their substitute for achievement.
