Help with selection of ASME b16.5 flange
Im an internship on this company and im helping with the design of a pressure vessel.
The working pressure is 8,1MPa, room temperature.
Based on table 2, 1.1 on ASME b16.5, class 600 would be enough (Working pressure = 10.21MPa).
My question is about safety factor. Does this standard take a safety factor already on this working pressure or i'd need to use class 900 (working pressure = 15.32MPa) to have a safety factor near 2 (probably 2 would be fine since fluid is water and mostly static state, no impacts or whatever).
Sorry if the question is kinda newbie, but im searching for that and i didnt find a simple answer. It has been only a month since i started learning about pressure vessels so my knowledge its still very limited.
Thanks in regard,
Felipe
Thanks in regard,
Felipe
RE: Help with selection of ASME b16.5 flange
Are you the engineer responsible for the design of this vessel? Design of pressure vessels is not something learned from an internship. It takes years under mentorship to understand the design process, and then still it's not something you can do on your own. Is there anybody in your company who has sufficient experience in PV design? If so, have him (or her) mentor you on such questions.
I help with the choices but the responsible is my mentor. Im kinda aware its complicated but he has a lot of experience in engineering so i guess he is aware as well.
Thanks for your help
