Pump shop performance test
I have a question on a suppliers shop test performed. The order called for a electric driven firewater pump with a 125 HP/1765 RPM motor to meet the design conditions. The supplier states that he used a 200HP/3500 RPM motor to test the pump in the shop and that it passed the performance test without giving any further information other than the pump curves. Is it possible to perform such a test with an overdesigned motor rating? how good is the pump after this testing?
RE: Pump shop performance test
The information reported to you is at best incomplete. At worst, well...
Bill
"Why not the best?"
Jimmy Carter
