Gathering manifold design
I would like to know the criteria to design a manifold which collects fluid
from ten different lines and joins it into one commun outlet line.
Does this manifold pipe need to be the same size than the outlet line or should I use different velocity and pressure drop criteria to design it?
Can this commun outlet line be placed anywhere along the manifold or is there an optimum configuration?
