how to define variable pressures direcctly on the plate elements
I acquired a FEM, which has not geometry information. I want to add the variable pressures directly on elements.
when i try to do model-load-elemental-pressure...i cant set the coord sys and the variable advanced settings. I know using model-load-elemental-surface I can do, but now the geometry model is not available. How can I add variable pressures directly on elements using FEMAP?
If there are the solutions. Please post your answers or send to my email: jiancheng.liu@vard.com
Many thanks.
regards,
Jiancheng
Many thanks.
regards,
Jiancheng
