See 3D diagram of a quantity as U and SM
I would ask to you, if in abaqus is possibile to see an output field as U1 or SM, instead of a color map as 3D diagram where at certain point's coordinate can be saw the value of the chose quantity.
i.e.
I have this output about a plate:
I wish obtain through abaqus an output like this: (i obtained this diagram with mathematica):
I wish obtain this for all components of U and SM. is it possible in abaqus ? :)
I attached the file *.cae
Thanks for the attention :)
RE: See 3D diagram of a quantity as U and SM
No.
Export the data (Report > Field Output) and use an external tool.
Mustaine3 you've been very kind.
