Adams/View model ready, setting maneuvers at Adams/View or export model to Adams/Car?
Hi friends here,
I'm working on a quad motorcycle model at Adams/View, the model is all setup with 14 DoF. Now I can't find how to make the software "know" for example which parts belongs to the steering system to start setting all the systems and start doing maneuvers for testing and getting data like camber angle change while the suspension travels or to plot lateral acceleration while doing a doble lane changing maneuver, etc.
My question is where to start doing that on Adams/View? Or if it is possible and easier to export the model to Adams/Car?
Thanks for reading.
Thanks for reading.
RE: Adams/View model ready, setting maneuvers at Adams/View or export model to Adams/Car?
So, I can't tell you how to do closed loop driving events in View (even in Car or Chassis they aren't particularly straightforward). Open loop is easy enough, define a speed, and then move your steering wheel with a MOTION statement. For example my most common test is called swept steer, that is just driving at constant speed and then applying a ramp signal to the SWA.
Cheers
Greg Locock
Cheers
Greg Locock
