remove set form dynamic temp disp explicit
I want to remove sets by using keyword
*MODEL CHANGE, REMOVE, TYPE=ELEMENT
workpiecenew-1.Set-1,
but this not working on dynamic temp-disp explicit it shows error-
This keyword is not available in abaqus/explicit.
my aim is to determine the stress and strain by applying the heat flux over the different surface and remove the set in each step.
rough image of my problem is attached
please help me
RE: remove set form dynamic temp disp explicit
Using *Import could be a workaround.
See Users Manual 9.2.4 Transferring results from one Abaqus/Explicit analysis to another
