Results Display
Results Display
Is there a way to control the load case of the results display with the drop down menu from the tool bar? I can use this load case drop down to cycle through the display of the loads, but the results (deflection, unity check) remain constant. I can change the display of the results by entering the model display options, but this is tedious to cycle through.
Thanks in advance for any advice.
RE: Results Display
RE: Results Display
Professional Engineer (ME, NH, MA) Structural Engineer (IL)
American Concrete Industries
https://www.facebook.com/AmericanConcrete/
RE: Results Display
Yes, you don't know what you have until it is gone.
RE: Results Display
RE: Results Display
