Foundation Rocking
Foundation Rocking
Foundation Rocking
Perhaps this is a silly question, but can somebody explain what implies the term rocking in foundation seismic retrofit?
RE: Foundation Rocking
It's when the seismic load on a building is capped by the foundation lifting off from the ground rather than by yielding of the superstructure. Link. Think shear walls tipping over. As the theory goes, once your reach a level of force that would rock the foundations in this way, no further force can be absorbed by the structure. For me, the challenge has always been coming up with a suitably conservative, but still useful, determination of how much load induces rocking.
Thanks KootK. Looks like rocking can be related to "Foundation yielding". However, not sure if that can be considered as the ultimate geotechnical capacity of the foundation.
Quote (Okiryu)
That might be possible but I'm accustomed to it essentially meaning whole building tipping / overturning without the wholesale yielding of foundation elements or the supporting soil.
Quote (Okiryu)
I would think not but, then, I'm not a geotechnical expert and I many not fully appreciate the meaning behind the terminology that you're using.
