NX Journal to export an Assembly report with Weigth, COG, Momentums per part
Hi All,
I have been searching this forum for while, really appreciate the support. I have been trying to make the journal from this link, thread561-332899: NX 7.5 - Export assembly BOM with part COG's: NX 7.5 - Export assembly BOM with part COG's , to work. Unfortunately I have just only been able to make it work for an specific seleccted part from the display. My aim would be to export to an Excel spreadsheet all data related to: Weight, Material, CoG position and Radius of Gyration per item contained in the assembly.
I have worked a lot with vba, but nearly nothing with Nx Journal, so any help will be much appreciated.
In my team, we need to prepare such spreadsheets quite often and I think this could save lot of time.
Many thanks in advance and apologies if this was not the right way to issue a thread.
JL Lancha
JL Lancha
RE: NX Journal to export an Assembly report with Weigth, COG, Momentums per part
Is there any issue with my explanation, got no replies... If the answer is already here I would appreciate if anyone could guide me.
Thank you in advance
www.nxjournaling.com
My intent is not to get the code right away, but some guidance on how to achieve what I need. I will have a look to the link provided as it sound it may work from there.
Thank you again for your support.
