Reactors on Substation Feeders
I was recently looking at a utility Substation that had 13.8kV MetalClad Switchgear with a double bus / double breaker arrangement which had reactors on each of the outgoing feeders. The reactors appear to be 1.5ohm/400A, 1.5ohm/600A and 1ohm/600A combos.
Are these reactors used simply for limiting fault current at the feeders downstream location or is there perhaps another reason why these reactors may be used?
RE: Reactors on Substation Feeders
J. Horak, P-R Engineering, Colorado
