AO Mirror doesn't hold steady
Recently I have noticed that my AO mirror doesn't stay at a setting consistently. When I am cutting along the edge of parts, intermittently, I can see the gauge on the mirror going up and down. It will bounce between 2 and 4.
I am unsure of why it would be doing that. It seems as though it no longer is regulating the air pressure that is pushing on it?... Please help.
Some days there are no problems. Mainly the issues arise on the thicker materials.
RE: AO Mirror doesn't hold steady
First thing I would check is the air supply to the regulator that controls pressure to the A/0. I have seen it connected to the beam purge instead of the the regular air supply.
The other options is the regulator is getting old and can't hold pressure. Years ago I bought one off eBay for about $100. It's easy to change out.
