Need help answering a question
Hi Guys,
I've been given some revision material for a control exam, but the one of the answers to the question is incomplete. Would someone help me answer it so i can start remembering it.
Q. For a general Direct Digital Control (DDC) system, discuss the practical hardware and software aspects that influence the selection of sampling increment, T.
This is the incomplete answer that was given:
A. Discussion should include computing speed, its relationship to sampling rate and characteristics of process quantity changes with time.
I must admit, I'm rubbish at control theory.. but can rely on my maths skills for the other questions. Could someone help answer this for me?
RE: Need help answering a question
Keith Cress
And, the microcontrollers clock speed will put a cap on the sampling rate anyway.
Do you think this is close?
If you assume a controller to start with, you might wind up with something that's completely useless. A control algorithm that's too laggy might was well not be there at all, since the lag will result in loop instability.
TTFN (ta ta for now)
