Need help in VB journal
Hi
This journal work OK when I removed the Resize plane code segment
and its also run with it but the orientation and location
of the plane allwase in the abs coord.
can someomne help correct it
Thank you in advanced
CODE -->
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module create_and_resize_plane
 Sub Main
   Dim theSession As Session = Session.GetSession()
   Dim ufs As UFSession = UFSession.GetUFSession()
   create_plane( )
 End Sub
 Sub create_plane( )
  '   ****** Create Datum plane ******
  Dim workPart As Part = theSession.Parts.Work
  Dim displayPart As Part = theSession.Parts.Display
  Dim wcs_origin As Point3d = workPart.WCS.Origin
  Dim wcs_matrix3x3 As Matrix3x3 = workPart.WCS.CoordinateSystem.Orientation.Element
  Dim featdatum_tag As Tag
  Dim featdatum_obj As NXObject
  Dim xyplane As DatumPlane
  xyplane = workPart.Datums.CreateFixedDatumPlane(wcs_origin,wcs_matrix3x3)
  xyplane.SetName("_XY_")
  ufs.Modl.AskObjectFeat(xyplane.Tag,featdatum_tag)
  featdatum_obj = NXOpen.Utilities.NXObjectManager.Get(featdatum_tag)
  Dim xy_PlaneFeat As Features.DatumPlaneFeature = CType(featdatum_obj,Features.DatumPlaneFeature)
  xy_PlaneFeat.SetName("_XY_")
'==================== Resize plane start ========================
   Dim nullFeature As NXOpen.Features.Feature = Nothing
   Dim resizePlaneBuilder1 As Features.ResizePlaneBuilder
   resizePlaneBuilder1 = workPart.Features.CreateResizePlaneBuilder(nullFeature)
   resizePlaneBuilder1.Plane.Value = xyplane
   resizePlaneBuilder1.ResizeDuringUpdate = False
   Dim d As Double = 3.0
   Dim p As Double = 1.0
   Dim n As Double = -1.0
   d = d/2
   Dim corners As Point3d() = {New Point3d(n*d, n*d, 0.0),New Point3d(p*d, n*d, 0.0), _
                                      New Point3d(p*d, p*d, 0.0),New Point3d(n*d, p*d, 0.0)}
   resizePlaneBuilder1.SetCornerPoints(corners)
   resizePlaneBuilder1.Commit()
   resizePlaneBuilder1.Destroy()
'====================== Resize plane end ======================
  Dim Xdir As New Point3d(1,0,0)
  Xdir = WCS2Abs(Xdir)
  Dim Xaxis As DatumAxis
  Xaxis = workPart.Datums.CreateFixedDatumAxis(wcs_origin,Xdir)
  Xaxis.SetName("_X_")
  ufs.Modl.AskObjectFeat(Xaxis.Tag,featdatum_tag)
  Dim x_AxisFeat As Features.DatumAxisFeature = CType(featdatum_obj,Features.DatumAxisFeature)
  x_AxisFeat.SetName("_X_")
  Dim Ydir As New Point3d(0,1,0)
  Ydir = WCS2Abs(Ydir)
  Dim Yaxis As DatumAxis
  Yaxis = workPart.Datums.CreateFixedDatumAxis(wcs_origin,Ydir)
  Yaxis.SetName("_Y_")
  ufs.Modl.AskObjectFeat(Yaxis.Tag,featdatum_tag)
  Dim y_AxisFeat As Features.DatumAxisFeature = CType(featdatum_obj,Features.DatumAxisFeature)
  y_AxisFeat.SetName("_Y_")
 End Sub
 Function WCS2Abs(ByVal inPt As Point3d) As Point3d
   Dim pt1(2), pt2(2) As Double
   pt1(0) = inPt.X
   pt1(1) = inPt.Y
   pt1(2) = inPt.Z
   ufs.Csys.MapPoint(UFConstants.UF_CSYS_ROOT_WCS_COORDS, pt1, UFConstants.UF_CSYS_ROOT_COORDS, pt2)
   WCS2Abs.X = pt2(0)
   WCS2Abs.Y = pt2(1)
   WCS2Abs.Z = pt2(2)
 End Function
 Public Function GetUnloadOption(ByVal dummy As String) As Integer
  'Unloads the image when the NX session terminates
  GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
 End Function
End Module
RE: Need help in VB journal
Hi
I added this code to check plane corners and I get all plane corners equale to zero
Do someone can see and help vwhats wrong here
Dim crnr1,crnr2,crnr3,crnr4 As Point3d
Dim crnrs As Point3d() = {crnr1,crnr2,crnr3,crnr4}
resizePlaneBuilder1.GetCornerPoints(crnrs)
msgbox(crnrs(0).ToString)
msgbox(crnrs(1).ToString)
msgbox(crnrs(2).ToString)
msgbox(crnrs(3).ToString)
CODE -->
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
 Sub Main
   create_plane( )
 End Sub
 Sub create_plane( )
   d = d/2
   Dim corner1 As Point3d = New Point3d(n*d, n*d, 0.0)
   Dim corner2 As Point3d = New Point3d(p*d, n*d, 0.0)
   Dim corner3 As Point3d = New Point3d(p*d, p*d, 0.0)
   Dim corner4 As Point3d = New Point3d(n*d, p*d, 0.0)
   Dim corners As Point3d() = {corner1,corner2,corner3,corner4}
 End Sub
   pt1(0) = inPt.X
   pt1(1) = inPt.Y
   pt1(2) = inPt.Z
   WCS2Abs.X = pt2(0)
   WCS2Abs.Y = pt2(1)
   WCS2Abs.Z = pt2(2)
 End Function
 End Function
End Module
I played around with the resize plane builder a little bit. It seems buggy or at least does not behave in an expected way. Below is a quick concept work-around that does not use the resize plane builder. Note that you can get the corner points from the datum plane object and you can specify the corner points in the datum plane builder object. By rewriting the code, you could create the plane and specify the corner points through the use of the datum plane builder object. Also note that this quick example assumes the WCS is set to absolute; if this is not the case, the new corner points will probably need to be translated to the desired csys.
CODE
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports Microsoft.VisualBasic
Imports System.Environment
Imports NXOpen.Features
Module create_pattern_sketch_from_list_and_file_options
 Sub Main
  Dim lw as listingwindow = theSession.ListingWindow
  lw.open
  'xyplane.SetName("_XY_")
  'lw.writeline("featdatum_obj type: " & featdatum_obj.Gettype.tostring)
  dim corner1 as point3d
  dim corner2 as point3d
  dim corner3 as point3d
  dim corner4 as point3d
  xyplane.GetCornerPoints(corner1, corner2, corner3, corner4)
  lw.writeline("initial corner 1: " & corner1.ToString)
  lw.writeline("initial corner 2: " & corner2.ToString)
  lw.writeline("initial corner 3: " & corner3.ToString)
  lw.writeline("initial corner 4: " & corner4.ToString)
  corner1.X = -4.0
  corner1.Y = -4.0
  corner2.X = 4.0
  corner2.Y = -4.0
  corner3.X = 4.0
  corner3.Y = 4.0
  corner4.X = -4.0
  corner4.Y = 4.0
  dim datumPlaneBuilder1 as features.DatumPlaneBuilder
  datumPlaneBuilder1 = workpart.Features.CreateDatumPlaneBuilder(featdatum_obj)
  datumPlaneBuilder1.SetCornerPoints(corner1, corner2, corner3, corner4)
  datumPlaneBuilder1.commit
  datumPlaneBuilder1.destroy
 End Sub
End Module
www.nxjournaling.com
Cowski thank you a lot
I see in the datumplane class there is also SetCornerPoints method
do I can use thise instead of building a DatumPlaneBuilder
xyplane.SetCornerPoints(corner1, corner2, corner3, corner4)
and also is the corners value is from the abs origin the class not say anything about
Thank you again
I created a datum plane then recorded a journal while resizing the plane, expecting it to return code showing how to use the resize plane builder. Instead, it returned code using the datum plane builder. I played around with the resize plane builder, but could not get it to do anything useful. That's when I went back to the recorded code and resized the plane with the datum plane builder. I didn't even notice that the plane object also has a .SetCornerPoints method; it should work, at least it is worth a try.
I succeeded to record it but I'm still stacked
CODE -->
' NX 8.5.3.3
' Journal created by I'm on Wed Apr 26 18:30:55 2017 Jerusalem Daylight Time
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
'   Menu: Edit->Feature->Resize Datum Plane...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
Dim nullFeatures_Feature As Features.Feature = Nothing
If Not workPart.Preferences.Modeling.GetHistoryMode Then
    Throw(New Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode."))
End If
resizePlaneBuilder1 = workPart.Features.CreateResizePlaneBuilder(nullFeatures_Feature)
theSession.SetUndoMarkName(markId1, "Resize Datum Plane Dialog")
Dim datumPlane1 As DatumPlane = CType(workPart.Datums.FindObject("FIXED_DATUM_PLANE(4)"), DatumPlane)
resizePlaneBuilder1.Plane.Value = datumPlane1
Dim coordinates1 As Point3d = New Point3d(19.0, 40.0, 0.0)
Dim point1 As Point
point1 = workPart.Points.CreatePoint(coordinates1)
Dim coordinates2 As Point3d = New Point3d(19.0, 40.0, 0.0)
Dim point2 As Point
point2 = workPart.Points.CreatePoint(coordinates2)
workPart.Points.DeletePoint(point1)
Dim coordinates3 As Point3d = New Point3d(19.0, 40.0, 0.0)
Dim point3 As Point
point3 = workPart.Points.CreatePoint(coordinates3)
workPart.Points.DeletePoint(point2)
Dim coordinates4 As Point3d = New Point3d(12.5056039948752, 46.7561165003932, -1.86223808775998)
Dim point4 As Point
point4 = workPart.Points.CreatePoint(coordinates4)
workPart.Points.DeletePoint(point3)
Dim coordinates5 As Point3d = New Point3d(19.0, 40.0, 0.0)
Dim point5 As Point
point5 = workPart.Points.CreatePoint(coordinates5)
workPart.Points.DeletePoint(point4)
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Resize Datum Plane")
theSession.DeleteUndoMark(markId2, Nothing)
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Resize Datum Plane")
Dim cornerpoints1(3) As Point3d
cornerpoints1(0) = New Point3d(9.38738304061681, 30.0, -2.75637355816999)
cornerpoints1(1) = New Point3d(28.6126169593832, 30.0, 2.75637355816999)
cornerpoints1(2) = New Point3d(28.6126169593832, 50.0, 2.75637355816999)
cornerpoints1(3) = New Point3d(9.38738304061681, 50.0, -2.75637355816999)
resizePlaneBuilder1.SetCornerPoints(cornerpoints1)
Dim nXObject1 As NXObject
nXObject1 = resizePlaneBuilder1.Commit()
theSession.DeleteUndoMark(markId3, Nothing)
theSession.SetUndoMarkName(markId1, "Resize Datum Plane")
'   Menu: Tools->Journal->Stop Recording
End Sub
End Module
I don't recommend using the resize plane builder.
Sorry I forgot to say that to build this I used
datum right click and chose the resize icon.
OK I'm very thank you.
Update: the resize plane builder can be made to work. The API reference shows that you should pass a reference to a datum plane feature to the builder (NX 9 docs), but the journal recorder disagrees. The journal recorder passes in a null feature and specifies the plane to be the plane of the datum plane feature; this method works. Note that the corner points will need to be transformed to absolute coordinates.
Hi Cowski
Thank you for the update.(make it clear for me which one work pass by reference or pass by null ?)
I found this code in the internet
can you learn something from it
Thank you again
CODE -->
def datum_plane(self, datum_origin, datum_normals, datum_corners):
        self.theLw.WriteLine('\n')
        self.theLw.WriteLine("Datum Plane function")
        for i in range(len(datum_corners)):
            datumPlaneBuilder = workPart.Features.CreateDatumPlaneBuilder(NXOpen.Features.Feature.Null)
            #returns an NX.Open Plane object, from DatumPlaneBuilder class
            plane = datumPlaneBuilder.GetPlane()
            geom = []
            plane.SetGeometry(geom)
            plane.SetUpdateOption(NXOpen.SmartObject.UpdateOption.WithinModeling)
            #using dist from plane to origin and a surface normal to create the plane
            plane.SetMethod(NXOpen.PlaneTypes.MethodType.Coefficients)
            origin = NXOpen.Point3d(datum_origin[i][0], datum_origin[i][1], datum_origin[i][2])
            plane.Origin = origin
            #a, b, c coefficients
            normal = NXOpen.Vector3d(datum_normals[i][0], datum_normals[i][1], datum_normals[i][2])
            plane.Normal = normal
            plane.Evaluate()
            datumPlaneBuilder.ResizeDuringUpdate=False
            datum_feat=datumPlaneBuilder.CommitFeature()
            #need to get journal Identifier of datum plane and pass it as an object
            self.theLw.WriteLine("Datum feature is "+str(datum_feat.JournalIdentifier))
            #create instance of resize plane
            resizePlaneBuilder = workPart.Features.CreateResizePlaneBuilder(NXOpen.Features.Feature.Null)
            datum_object = workPart.Datums.FindObject(str(datum_feat.JournalIdentifier))
            resizePlaneBuilder.Plane.Value = datum_object
            resizePlaneBuilder.ResizeDuringUpdate = False
            corner_pts = [None] * 4
            #multiplying by a scale factor just moves the planes further out
            # to adjust size, recalculate your corner points
            corner_pts[0] = NXOpen.Point3d(datum_corners[i][0][0],datum_corners[i][0][1],datum_corners[i][0][2])
            corner_pts[1] = NXOpen.Point3d(datum_corners[i][1][0],datum_corners[i][1][1],datum_corners[i][1][2])
            corner_pts[2] = NXOpen.Point3d(datum_corners[i][3][0],datum_corners[i][3][1],datum_corners[i][3][2])
            corner_pts[3] = NXOpen.Point3d(datum_corners[i][2][0],datum_corners[i][2][1],datum_corners[i][2][2])
            resizePlaneBuilder.SetCornerPoints(corner_pts)
            resizePlaneBuilder.Commit()
            resizePlaneBuilder.Destroy()
            datumPlaneBuilder.Destroy()
The code creates a datum plane then resizes it according to the corner coordinates it was given. What issue are you having with the code?
Cowski I'lm very thank you
I don't successed to do this task
and I want to trying this.
PLEASE can translate it to VB
for me
The below is essentially a straight conversion from the Python code to VB. I make no guarantees on its fitness for use.
CODE
Sub CreateDatumPlanes(ByVal datumOrigins As List(Of Point3d),
                         ByVal datumNormals As List(Of Vector3d),
                         ByVal datumCorners As List(Of List(Of Point3d)))
        For i As Integer = 0 To datumOrigins.Count - 1
            Dim dPlaneBuilder1 As Features.DatumPlaneBuilder = theSession.Parts.Work.Features.CreateDatumPlaneBuilder(Nothing)
            Dim thePlane As Plane = dPlaneBuilder1.GetPlane
            Dim geom(-1) As NXObject
            thePlane.SetGeometry(geom)
            thePlane.SetUpdateOption(SmartObject.UpdateOption.WithinModeling)
            thePlane.SetMethod(PlaneTypes.MethodType.Coefficients)
            thePlane.Origin = datumOrigins.Item(i)
            thePlane.Normal = datumNormals.Item(i)
            thePlane.Evaluate()
            dPlaneBuilder1.ResizeDuringUpdate = False
            Dim datumFeature As Features.DatumPlaneFeature = dPlaneBuilder1.CommitFeature
            dPlaneBuilder1.Destroy()
            Dim resizePlaneBuilder1 As Features.ResizePlaneBuilder = theSession.Parts.Work.Features.CreateResizePlaneBuilder(Nothing)
            resizePlaneBuilder1.Plane.Value = datumFeature.DatumPlane
            resizePlaneBuilder1.SetCornerPoints(datumCorners.Item(i).ToArray)
        Next
    End Sub
Cowski thank you for the time
you invested for me.
Hi Cowski
I played around with your ("I played around with the resize plane builder a little bit")
and finally arrived to this working journal. (your help is active and I'm thank you)
now I go to do the same for the X,Y axis (I hope to succede)
my goal is to adjust a working plane to my sizes
CODE -->
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
 Sub Main
  lw.open
  Dim plane_size As Double = 40
  corner1.X = -0.5*plane_size
  corner1.Y = -0.5*plane_size
  corner1.Z = 0
  corner2.X = 0.5*plane_size
  corner2.Y = -0.5*plane_size
  corner2.Z = 0
  corner3.X = 0.5*plane_size
  corner3.Y = 0.5*plane_size
  corner3.Z = 0
  corner4.X = -0.5*plane_size
  corner4.Y = 0.5*plane_size
  corner4.Z = 0
  corner1 = WCS2Abs(corner1)
  corner2 = WCS2Abs(corner2)
  corner3 = WCS2Abs(corner3)
  corner4 = WCS2Abs(corner4)
  lw.writeline("=======================================================")
  lw.writeline("last corner 1: " & corner1.ToString)
  lw.writeline("last corner 2: " & corner2.ToString)
  lw.writeline("last corner 3: " & corner3.ToString)
  lw.writeline("last corner 4: " & corner4.ToString)
 End Sub
   pt1(0) = inPt.X
   pt1(1) = inPt.Y
   pt1(2) = inPt.Z
   WCS2Abs.X = pt2(0)
   WCS2Abs.Y = pt2(1)
   WCS2Abs.Z = pt2(2)
 End Function
End Module
Final solution
CODE -->
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpenUI.NXInputBox
Module create_plane_and_axis_on_xcyc_xczc_yczc
 Sub Main
  Dim dpsize As Double = 0
  Dim dPlane As String
  Dim mPlaneDir As Integer = 1
  Dim mPlaneSize As Double = 25
  Dim f1 As UserInputDialog = New UserInputDialog
  f1.dPlaneDir = mPlaneDir
  f1.dPlaneSize = mPlaneSize
  If f1.ShowDialog() <> DialogResult.OK Then Exit Sub
  mPlaneDir = f1.dPlaneDir
  mPlaneSize = f1.dPlaneSize
  Dim my_markId1 As Session.UndoMarkId = _
               theSession.SetUndoMark(Session.MarkVisibility.Visible,"Create plane")
  If mPlaneDir = 1 Then
      dPlane = "XY"
  Else If mPlaneDir = 2 Then
      dPlane = "XZ"
  Else If mPlaneDir = 3 Then
      dPlane = "YZ"
  End If
  dpsize = mPlaneSize
  Dim wcs_org_matrix3x3 As Matrix3x3 = CopyMatrix3x3(wcs_matrix3x3) 'save original WCS direction
  If dplane = "XZ" Then
     displayPart.WCS.Rotate(WCS.Axis.XAxis, 90) ' rotate XY to simulate the XZ plane
  End If
  If dplane = "YZ" Then
     displayPart.WCS.Rotate(WCS.Axis.YAxis, 90) ' rotate XY to simulate the YZ plane
  End If
  wcs_matrix3x3 = workPart.WCS.CoordinateSystem.Orientation.Element 'get matrix of rotation
'---- XY segment start
  If dplane = "XY" Then
    xyplane.Feature.SetName("_XY_")
  Else If dplane = "XZ" Then
    xyplane.Feature.SetName("_XZ_")
  Else If dplane = "YZ" Then
    xyplane.Feature.SetName("_YZ_")
  End If
  Dim corner1,corner2,corner3,corner4 As point3d
  Dim plane_size As Double = dpsize
  corner1.X = -0.5*plane_size : corner1.Y = -0.5*plane_size : corner1.Z = 0
  corner2.X = 0.5*plane_size : corner2.Y = -0.5*plane_size : corner2.Z = 0
  corner3.X = 0.5*plane_size : corner3.Y = 0.5*plane_size : corner3.Z = 0
  corner4.X = -0.5*plane_size : corner4.Y = 0.5*plane_size : corner4.Z = 0
  corner1 = WCS2Abs(corner1) : corner2 = WCS2Abs(corner2)
  corner3 = WCS2Abs(corner3) : corner4 = WCS2Abs(corner4)
  workPart.WCS.SetOriginAndMatrix (wcs_origin,wcs_org_matrix3x3) 'restore original WCS direction
'---- X segment start
  Dim Xdir As Point3d
     Xdir = New Point3d(1,0,0)
     Xdir = New Point3d(0,1,0)
  End If
  Dim start1,end1 As Point3d
  Xaxis.GetEndPoints(start1,end1)
    Xaxis.Feature.SetName("_X_")
    end1.X = 0.75*dpsize : end1.Y = 0 : end1.Z = 0
    Xaxis.Feature.SetName("_Y_")
    end1.X = 0 : end1.Y = 0.75*dpsize  : end1.Z = 0
  End If
  end1 = WCS2Abs(end1)
  Xaxis.SetEndPoints(start1,end1)
'---- Y segment start
  Dim Ydir As Point3d
     Ydir = New Point3d(0,1,0)
     Ydir = New Point3d(0,0,1)
  End If
    Yaxis.Feature.SetName("_Y_")
    Yaxis.Feature.SetName("_Z_")
    end1.X = 0 : end1.Y = 0 : end1.Z = 0.75*dpsize
  End If
  Yaxis.SetEndPoints(start1,end1)
 End Sub
'=============================   Routines   ====================================
   pt1(0) = inPt.X
   pt1(1) = inPt.Y
   pt1(2) = inPt.Z
   WCS2Abs.X = pt2(0)
   WCS2Abs.Y = pt2(1)
   WCS2Abs.Z = pt2(2)
 End Function
 Function CopyMatrix3x3(ByVal org_mat As Matrix3x3) As Matrix3x3
   Dim mx As Matrix3x3
     mx.Xx = org_mat.Xx
     mx.Xy = org_mat.Xy
     mx.Xz = org_mat.Xz
     mx.Yx = org_mat.Yx
     mx.Yy = org_mat.Yy
     mx.Yz = org_mat.Yz
     mx.Zx = org_mat.Zx
     mx.Zy = org_mat.Zy
     mx.Zz = org_mat.Zz
   Return mx
 End Function
 End Function
End Module
'*********************************  Class  ****************************
' Form Class
' A form for the user to input data
Public Class UserInputDialog
             Inherits System.Windows.Forms.Form
 Private Sub UserInputDialog_Load(ByVal sender As System.Object, _
                                     ByVal e As System.EventArgs) Handles MyBase.Load
   'ttHint.SetToolTip(Me.XZRadioButton, "Create plane on XC-ZC")
   'ttHint.SetToolTip(CancelButton, "Cancel Button")
   If dPlaneDir = 1 Then
     XYRadioButton.Checked = True
   Else If dPlaneDir = 2
     XZRadioButton.Checked = True
   Else
     YZRadioButton.Checked = True
   End If
   PlaneSizeTextBox.Text = dPlaneSize
 End Sub
    ' Public Variables
    Public dPlaneList() As String
    Public dPlaneDir As Integer
    Public dPlaneSize As Double
    Public dPttrnFileName As String
    Public dSelectedPlane As String
    Public dSelectedIndex As Integer
    ' Public Method
    Public Sub New()
        MyBase.New()
        'This call is required by the Windows Form Designer.
        InitializeComponent()
       'NX icon in top left side
        NXOpenUI.FormUtilities.SetApplicationIcon(Me)
        NXOpenUI.FormUtilities.ReparentForm(Me)
    End Sub
    'Form overrides dispose to clean up the component list.
    Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)
        If disposing Then
            If Not (components Is Nothing) Then
                components.Dispose()
            End If
        End If
        MyBase.Dispose(disposing)
    End Sub
    'Required by the Windows Form Designer
    Private components As System.ComponentModel.IContainer
    'NOTE: The following procedure is required by the Windows Form Designer
    'Inserted by the Windows Form Designer
    Friend WithEvents ttHint As System.Windows.Forms.ToolTip
    Friend WithEvents PlaneSizeLabel As System.Windows.Forms.Label
    Friend WithEvents OkButton As System.Windows.Forms.Button
    Friend WithEvents XYRadioButton As System.Windows.Forms.RadioButton
    Friend WithEvents XZRadioButton As System.Windows.Forms.RadioButton
    Friend WithEvents YZRadioButton As System.Windows.Forms.RadioButton
    Friend WithEvents CancelButton As System.Windows.Forms.Button
    Private WithEvents PlaneSizeTextBox As NumericTextBox
    <System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()
        Me.components = New System.ComponentModel.Container
        Me.ttHint = New System.Windows.Forms.ToolTip(Me.components)
        Me.OkButton = New System.Windows.Forms.Button
        Me.CancelButton = New System.Windows.Forms.Button
        Me.XYRadioButton = New System.Windows.Forms.RadioButton
        Me.XZRadioButton = New System.Windows.Forms.RadioButton
        Me.YZRadioButton = New System.Windows.Forms.RadioButton
        Me.PlaneSizeLabel = New System.Windows.Forms.Label
        Me.PlaneSizeTextBox = New NumericTextBox(1.0)
        Me.SuspendLayout()
        'OkButton
        Me.OkButton.DialogResult = DialogResult.OK
        Me.OkButton.Location = New System.Drawing.Point(30, 90)
        Me.OkButton.Name = "OkButton"
        Me.OkButton.Size = New System.Drawing.Size(130, 26)
        Me.OkButton.TabIndex = 11
        Me.OkButton.Text = "OK"
        'CancelButton
        Me.CancelButton.DialogResult = System.Windows.Forms.DialogResult.Cancel
        Me.CancelButton.Location = New System.Drawing.Point(254, 90)
        Me.CancelButton.Name = "CancelButton"
        Me.CancelButton.Size = New System.Drawing.Size(90, 26)
        Me.CancelButton.TabIndex = 12
        Me.CancelButton.Text = "Cancel"
        'XYRadioButton
        Me.XYRadioButton.Location = New System.Drawing.Point(10, 5)
        Me.XYRadioButton.Name = "XYRadioButton"
        Me.XYRadioButton.Size = New System.Drawing.Size(240, 28)
        Me.XYRadioButton.TabIndex = 0
        Me.XYRadioButton.Text = "XY Create plane on XC-YC"
        'XZRadioButton
        Me.XZRadioButton.Location = New System.Drawing.Point(10, 30)
        Me.XZRadioButton.Name = "XZRadioButton"
        Me.XZRadioButton.Size = New System.Drawing.Size(240, 27)
        Me.XZRadioButton.TabIndex = 1
        Me.XZRadioButton.Text = "XZ Create plane on XC-ZC"
        'YZRadioButton
        Me.YZRadioButton.Location = New System.Drawing.Point(10, 55)
        Me.YZRadioButton.Name = "YZRadioButton"
        Me.YZRadioButton.Size = New System.Drawing.Size(240, 27)
        Me.YZRadioButton.TabIndex = 1
        Me.YZRadioButton.Text = "YZ Create plane on YC-ZC"
        'PlaneSizeLabel
        Me.PlaneSizeLabel.Location = New System.Drawing.Point(232, 30)
        Me.PlaneSizeLabel.Name = "PlaneSizeLabel"
        Me.PlaneSizeLabel.Size = New System.Drawing.Size(72, 19)
        Me.PlaneSizeLabel.TabIndex = 7
        Me.PlaneSizeLabel.Text = "Plane Size"
        'PlaneSizeTextBox
        Me.PlaneSizeTextBox.Location = New System.Drawing.Point(302, 30)
        Me.PlaneSizeTextBox.Name = "PlaneSizeTextBox"
        Me.PlaneSizeTextBox.Size = New System.Drawing.Size(60, 20)
        Me.PlaneSizeTextBox.TabIndex = 9
        'Form1
        Me.AutoScaleBaseSize = New System.Drawing.Size(6, 15)
        Me.CancelButton = Me.CancelButton
        Me.ClientSize = New System.Drawing.Size(374, 130)
        Me.Controls.Add(Me.PlaneSizeTextBox)
        Me.Controls.Add(Me.PlaneSizeLabel)
        Me.Controls.Add(Me.XYRadioButton)
        Me.Controls.Add(Me.XZRadioButton)
        Me.Controls.Add(Me.YZRadioButton)
        Me.Controls.Add(Me.CancelButton)
        Me.Controls.Add(Me.OkButton)
        Me.Name = "Form1"
        Me.Text = "Create Plane     Company : Dev name"
        Me.ResumeLayout(False)
    End Sub
    ' A TextBox that only accepts floating point numbers greater than 1.0e-5
    Private Class NumericTextBox
        Inherits TextBox
        Public Sub New(ByVal x As Double)
            MyBase.New()
            m_value = x
            Me.Text = x.ToString()
        End Sub
        Public ReadOnly Property Value() As Double
            Get
                Return m_value
            End Get
        End Property
        Public Overrides Property Text() As String
            Get
                Return MyBase.Text
            End Get
            Set(ByVal text As String)
                m_value = Double.Parse(text)
                MyBase.Text = text
            End Set
        End Property
        Protected Overrides Sub OnValidating(ByVal e As System.ComponentModel.CancelEventArgs)
            ' Accept the input only if it is a floating point number
            ' greater than 1.0e-5
            Dim valid As Boolean = False
            Dim value As Double
            Try
                value = Double.Parse(Me.Text)
                If value > 0.00001 Then valid = True
            Catch ex As Exception
            End Try
            If valid Then
                m_value = value
            Else
                Me.Text = m_value.ToString
                e.Cancel = True
                MessageBox.Show( _
                "Invalid Input" & NewLine & "A positive number greater than 1.0e-5 is required")
            End If
            MyBase.OnValidating(e)
        End Sub
        Protected Overrides Sub OnKeyPress(ByVal e As KeyPressEventArgs)
            ' If Enter is pressed, move to the next control
            ' (Attempting to move to the next control will automatically cause
            ' OnValidating to be called for this control, and the move will
            ' not be permitted if validation fails.)
            If e.KeyChar = Chr(13) Then
                Me.Parent.SelectNextControl(Me, True, False, False, True)
            End If
            MyBase.OnKeyPress(e)
        End Sub
        Private m_value As Double
    End Class
    Private Sub XYRadioButton_Click(ByVal sender As System.Object, _
                      ByVal e As System.EventArgs) Handles XYRadioButton.Click
        dPlaneDir = 1
    End Sub
    Private Sub XZRadioButton_Click(ByVal sender As System.Object, _
                     ByVal e As System.EventArgs) Handles XZRadioButton.Click
        dPlaneDir = 2
    End Sub
    Private Sub YZRadioButton_Click(ByVal sender As System.Object, _
                     ByVal e As System.EventArgs) Handles YZRadioButton.Click
        dPlaneDir = 3
    End Sub
    Private Sub OkButton_Click(ByVal sender As Object, _
                             ByVal e As System.EventArgs) Handles OkButton.Click
        dPlaneSize = PlaneSizeTextBox.Value
    End Sub
End Class
