Curb ramps over a joint detail
Does anyone have a detail from previous projects of a curb ramp over a joint or where I could find one?
RE: Curb ramps over a joint detail
Is this part of a ramp with a curb going over an expansion joint?
If so, just provide a joint in the curb/ramp to match the existing joint. Seal it as required. If large joint, consider using a commercial joint cover or fab one using HDG steel for light use and stainless steel for heavy use.
Dik
