Place simple/countersunk holes on internal surface of cylinder
Hi all,
I have been trying to place simple/countersunk holes on the inner surface of a cylinder. I projected the point from the outside surface and the axis is "normal to face". This approach works in many previous cases but fails this time. I kept getting "the tool and target do not form a complete intersection."
Is there any other approach that allows users to have a countersunk hole on the inside surface of a cylinder?
RE: Place simple/countersunk holes on internal surface of cylinder
Are you selecting the inner surface as the face for placing the hole?
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Also to help troubleshoot the construction, try using the option to create the tool-body instead of actually creating the hols feature. This might help to give you a hint as to what might be happening.
Irvine, CA
Siemens PLM:
UG/NX Museum:
Hi John,
Yes, I selected the inner surface as the face for placing holes. It is because the countersunk has to start from the inside.
In fact, I just solve this problem by enabling the "Extend Start" from the hole feature setting.
Thanks anyways.
