One session of r14 at a time???
I know there is a registry setting or some thing that I can change to allow multiple sessions of autocad to open. As at the moment I can only open the one session.
Does any one know how to change this???
RE: One session of r14 at a time???
2. From the View menu, choose Options.
3. Select the File Types tab.
4. Select AutoCAD Drawing from the list, and then choose Edit.
5. In the Edit File Type dialog box under Actions, select Open, then choose Edit.
6. In the "Editing Action for type" dialog box, clear the Use DDE check box.
7. Choose OK, then choose Close twice.
You can now open more then one AutoCAD Release 14 drawing from Windows Explorer.
