Butterfly valves
Butterfly valves
Butterfly valves
Hi ,
one of the client asked about double eccentric butterfly valves Duplex SS disk with some additional data and accessories as below ,
1. Density value ( 1.5 kg/cubic m )
2. shut of pressure ( 12 bar )
3. Compressibility (0.09956 )
4. Actuator stroke time ( 300mm per minute ) motor operated
5. mechanical position indicator including position indicator light )
6. Torque switch
7. limit switch
8. Reversing starter
9. Motor overload protection
10.Anti-condensation heater
11.Push-button switch
12.Selector switch
kindly any one one have an experience in above requirements , plz clarify
Ahmad
RE: Butterfly valves
The valve is fine. What is important is the application and brand name which have not been mentioned.
thank you , but any more clarification regarding above points ?
Ahmad
