Limit of mast from taxiway center
Hi Engineers,
What is the limit of a sensor mast (height = 10m) from the center of a taxiway?
Any reference and recommendation?
RE: Limit of mast from taxiway center
Most aviation regulatory authorities such as the FAA publish such information but the airport may have its own operational documents that show such limits. Its normally around approach and departure funnels and transitional slopes.
Ashtree
"Any water can be made potable if you filter it through enough money"
https://www.faa.gov/airports/engineering/design_st...
Ashtree
