Gravity flow through 500 micron basket.
I need to calculate what flow rate is possible to achieve through a 500 micron mesh basket. Gravity scenario as Basket will be located in a floor drain.
I imagine head over the outlet and surface area opening of the basket but not sure which formula to use.
Thanks in advance
K
RE: Gravity flow through 500 micron basket.
Consult the vendor (or a vendor) literature.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
The manufacturer should have flow charts. There is no method to accurately calculate the head loss.
Just remember that the dirty state will generate a lot more head loss than clean....
At 0.5mm hole size I can't see a floor drain lasting very long before it gets very clogged and the head loss for any decent flow rate such that you will have a flood.
the odd plastic bag also has a detrimental effect....
From MIFAB, (http://www.mifab.com/Catalog/Library/f-selection-g...)
Q = 448.2 • Cd • A • (2 • g • h)^0.5
Q = Flow rate (Gallons per Minute)
Cd = Discharge Coefficient = 0.6
A = Free area (open area) of grate (ft/s^2 )
g = Acceleration (32.2 ft/s^2 )
h = Head above the floor (ft)
500 micron is huge for pure water. That's 35 Mesh. It's tiny for the trash that's in the water though.
Good luck,
Latexman
Thanks all.
Think a physical test best option.
There are vendor flow vs head loss curves for these basket strainers. To this estimated pressure drop, include a multiplier to account for fouling of the strainer - I typically use 1.0 for clean service, 2.0 for light fouling, and 3.0 for fouling.
