Attributes in Template Part Spreadsheet?
Is it possible to include attributes in the spreadsheet of a template part?
So that if you use Edit Reusable Component, the expressions and attributes change depending on your selection.
Part Families are able to control attributes thanks to an internal spreadsheet.
Is this functionality also possible for template parts, that are meant to be cloned?
Below a quote of NX-documentation under Create a reusable component in Teamcenter
"A member of a part family of commercial standard parts i.e. screws, bolts, washers, and nuts can only be added by reference. Template parts are parametric components that are linked to an external spreadsheet that drive the dimensional changes, and can be either cloned or referenced."
I'm using NX11 with TC10.
