PTFE conversion to powder or liquid or gas
Hi
I have a need to remove a long tube of PTFE even in destructive means
Is there any chemicals or process which could convert physical properties of PTFE into non solid form - ie powder liquid or gas?
RE: PTFE conversion to powder or liquid or gas
Very high temperature steam.
www.tynevalleyplastics.co.uk
Politicians like to panic, they need activity. It is their substitute for achievement.
Any one has an experience of cutting PTFE with laser? how deep penetration could be does it produce toxic fume?
Sodium will defluorinate it, and will make it crumble into dust. The resulting compounds aren't toxic, but sodium is dangerous to handle. I'm not sure why the defluorination causes the PTFE material to lose coehsion but it certainly seems to.
B.E.
You are judged not by what you know, but by what you can do.
Straight or curved?
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
True , but it goes straight from a solid to a gas.
Which is what I was trying to get across.
B.E.
