Can someone help me with this code snippet
Hi
Please can someone help in converting this python code to vb
Thank you very much
CODE -->
def datum_plane(self, datum_origin, datum_normals, datum_corners):
        self.theLw.WriteLine('\n')
        self.theLw.WriteLine("Datum Plane function")
        for i in range(len(datum_corners)):
            datumPlaneBuilder = workPart.Features.CreateDatumPlaneBuilder(NXOpen.Features.Feature.Null)
            #returns an NX.Open Plane object, from DatumPlaneBuilder class
            plane = datumPlaneBuilder.GetPlane()
            geom = []
            plane.SetGeometry(geom)
            plane.SetUpdateOption(NXOpen.SmartObject.UpdateOption.WithinModeling)
            #using dist from plane to origin and a surface normal to create the plane
            plane.SetMethod(NXOpen.PlaneTypes.MethodType.Coefficients)
            origin = NXOpen.Point3d(datum_origin[i][0], datum_origin[i][1], datum_origin[i][2])
            plane.Origin = origin
            #a, b, c coefficients
            normal = NXOpen.Vector3d(datum_normals[i][0], datum_normals[i][1], datum_normals[i][2])
            plane.Normal = normal
            plane.Evaluate()
            datumPlaneBuilder.ResizeDuringUpdate=False
            datum_feat=datumPlaneBuilder.CommitFeature()
            #need to get journal Identifier of datum plane and pass it as an object
            self.theLw.WriteLine("Datum feature is "+str(datum_feat.JournalIdentifier))
            #create instance of resize plane
            resizePlaneBuilder = workPart.Features.CreateResizePlaneBuilder(NXOpen.Features.Feature.Null)
            datum_object = workPart.Datums.FindObject(str(datum_feat.JournalIdentifier))
            resizePlaneBuilder.Plane.Value = datum_object
            resizePlaneBuilder.ResizeDuringUpdate = False
            corner_pts = [None] * 4
            #multiplying by a scale factor just moves the planes further out
            # to adjust size, recalculate your corner points
            corner_pts[0] = NXOpen.Point3d(datum_corners[i][0][0],datum_corners[i][0][1],datum_corners[i][0][2])
            corner_pts[1] = NXOpen.Point3d(datum_corners[i][1][0],datum_corners[i][1][1],datum_corners[i][1][2])
            corner_pts[2] = NXOpen.Point3d(datum_corners[i][3][0],datum_corners[i][3][1],datum_corners[i][3][2])
            corner_pts[3] = NXOpen.Point3d(datum_corners[i][2][0],datum_corners[i][2][1],datum_corners[i][2][2])
            resizePlaneBuilder.SetCornerPoints(corner_pts)
            resizePlaneBuilder.Commit()
            resizePlaneBuilder.Destroy()
            datumPlaneBuilder.Destroy()
RE: Can someone help me with this code snippet
Hi
I followed the above example (found on the enternet) and I get an ERROR
can someone help whats wrong.
Thanks in advanced
CODE -->
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports Microsoft.VisualBasic
Imports System.Environment
Imports NXOpen.Features
Module create_pattern_sketch_from_list_and_file_options
 Sub Main
  Dim theSession As Session = Session.GetSession()
  Dim workPart As Part = theSession.Parts.Work
  Dim displayPart As Part = theSession.Parts.Display
  Dim ufs As UFSession = UFSession.GetUFSession()
  Dim wcs_origin As Point3d = workPart.WCS.Origin
  Dim wcs_matrix3x3 As Matrix3x3 = workPart.WCS.CoordinateSystem.Orientation.Element
  Dim featdatum_tag As Tag
  Dim featdatum_obj As NXObject
  Dim xyplane As DatumPlane
  xyplane = workPart.Datums.CreateFixedDatumPlane(wcs_origin,wcs_matrix3x3)
  xyplane.SetName("_XY_")
  ufs.Modl.AskObjectFeat(xyplane.Tag,featdatum_tag)
  featdatum_obj = NXOpen.Utilities.NXObjectManager.Get(featdatum_tag)
  Dim xy_PlaneFeat As Features.DatumPlaneFeature = CType(featdatum_obj,Features.DatumPlaneFeature)
  xy_PlaneFeat.SetName("_XY_")
   Dim nullFeature As NXOpen.Features.Feature = Nothing
   Dim resizePlaneBuilder1 As Features.ResizePlaneBuilder
   resizePlaneBuilder1 = workPart.Features.CreateResizePlaneBuilder(nullFeature)
   resizePlaneBuilder.Plane.Value = xy_PlaneFeat
   resizePlaneBuilder1.ResizeDuringUpdate = False
   Dim corners As Point3d() = {New Point3d(-4.0, -4.0, 0.0),New Point3d(4.0, -4.0, 0.0), _
                                      New Point3d(4.0, 4.0, 0.0),New Point3d(-4.0, 4.0, 0.0)}
   resizePlaneBuilder1.SetCornerPoints(corners)
   resizePlaneBuilder1.Commit()
   resizePlaneBuilder1.Destroy()
 End Sub
End Module
