How to create start parts in Catia v5....
Does catia have the same start model functionality as Pro/ENGINEER?  Any suggestions would be great.  Thank you in advance.
RE: How to create start parts in Catia v5....
hi,
I try several things but what I find the best is a macro in VBA calling a dialog box where you can select the start file you want, using the start from file command.
The problem is that you have to use the macro and not the new file...
Happy New Year,
Eric N.
catiav5@softhome.net
