Beam Deflection Question
Hi all,
I've been working through some designs at work, and I came across a condition of loading where I was unsure of the way to calculate actual deflection. I had 3 unequal point loads, unevenly spaced.
For example:
l = 10ft
P1 = 1kip
x1 = 1ft
P2 = 2kip
x2 = 3ft
P3 = 1.5kip
x3 = 7ft
At first, I figured a simplified way to calculate this was complete a deflection calculation of each individual deflection and sum the results. Would this provide a close enough, preferably more conservative, deflection calculation?
For example:
l = 10ft
P1 = 1kip
x1 = 1ft
P2 = 2kip
x2 = 3ft
P3 = 1.5kip
x3 = 7ft
RE: Beam Deflection Question
Sometimes for a quick first run I'll sum the loads and apply then as a single point load at midspan. I've got that deflection formula memorized. If that beam size comes back reasonable, then no need to go further.
BA
http://webstructural.com/beam-designer.html
R.Efendy
I'm familiar with Alex Tomanovich's "BEAMANAL" spreadsheet, but I am not familiar with the (P*(L-a)^3)/(6EI) equation he uses for multiple point load situations. I figured it could have been a simplification towards a more conservative route.
I think it is a good "waste of time" to do the hand calcs yourself at least once.
I think it's an excellent idea to look at different ways of applying these loads (like a single mid-span load (most conservative) or as a UDL (least conservative) to develop your own feel for the solution (and not rely on something you read on the internet)
It will hardly take a few minutes to get the equation for the deflection at any point using double integration/McCaulay's method.
equating the slope equation to zero, the location of max. deflection and thereby he max. deflection can be found.
