dissmantling joint , flange adapter and coubling
Hi ,
what is the purpose of using dismantling joint , flange adapter and coupling in the water networks and when they use each one ?
Ahmad
Ahmad
RE: dissmantling joint , flange adapter and coubling
I mean really, what is anyone supposed to make of a vague one line query???
Flange adapter and coupling and mean different things in different countries. Typically a flange adapter i would take to mean as a conversion from a rubber ring or solvent weld type fitting to a flange of the same pipe size. A coupling typically means a female to female or socket to socket rubber ring or solvent weld pipe joiner.
If you asking whether these items can be interchanged or do the same job, the answer is no.
Ashtree
"Any water can be made potable if you filter it through enough money"
