how to module 2 slabs with small levels differences
Hello everybody,
I have 2 slabs with 0.5m level differences with beam connect the 2 slab (0.5m depth)
what is the best way to module the two slabs
I reach to different ways like:
1) drawing the 2 slabs in the same level with beam 0.5m depth.
2) drawing the 2 slabs in the actual levels and connect between them with wall has spandrel modifiers
3) drawing the 2 slabs in the actual levels and connect between them with 0.25m depth in each level (half of stifness in each level) and conncet between 2 slabs with link column (0.5m length)
*what is the best way or if there are any other ways ?
Thanks for advice.
Thanks for advice.
