circular tubes for heat transfer in boiler
Dear Sir
I have question in mind that why circular tubes used and not square or rectangular tubes for heat tranfer in boilers? Instead of no of circular tubes why no no of square or rectangular tubes for this purpose/
Pradeep
Pradeep
RE: circular tubes for heat transfer in boiler
Still, they might give better heat transfer in some configurations, i.e., if they can induce some extra turbulence on the shell side.
But the most likely answer is that there's no simple way to terminate the ends of square/rectangular tubes to a tubesheet.
You could use square tubes that are formed with round ends and terminate them in the usual way, but that leaves no way to replace individual tubes, e.g., pulling a square tube through a round hole.
Note that obround tubes are used extensively in automobile radiators, but they are never individually replaced, and are assembled with external fins, for which the flattened sides are a great advantage in conducting heat from the tube wall to the fin material.
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
Oblong tubes are used in air cooled condensers installed in freezing climates, since they can survive several ice freezing events without cracking. Their design pressure is only +- 1 atm, so wall thickness is not an issue.
Oblong tubes also have minimal frictional pressure drop for the outside flowing flue gas if the major axis is parallel to the fluegas direction ( eg Joukowski airfoil) but this also means low convective heat transfer coefficient- to offset that penalty, extended fins are added.
I am not talking about advantage or disadvantage of using square or other non circular shape. I am just asking for curiosity that any specific reason for circular tubes
Pradeep
Your question was answered several times. If there's no benefit, then there is no engineering reason for choosing them, particularly since they are hard to make and harder to form.
TTFN (ta ta for now)
Why u sent Yutube video and Forum policies? I also know that my question answered but with every new answer new information I came to know. Is'nt good that every one get to know new information.
