Welding operations
Welding operations
Welding operations
What is the definition of welding operations? I have seen it used in some codes but not defined. Do any codes define it? I believe it is just the process of welding or does it include the grinding and other activities between passes as well?
RE: Welding operations
Welding Operations is from start (cleaning, preheat) to actual welding using a welding process or processes (interpass temperature, cleaning (if applicable) and the completion of welding (cooling or after PWHT).
OP, there are several codes or specs that define welding operations. In my company, we perform a significant amount of structural welding, which is controlled by AWS D1.1. Have a look at AWS' website for more information. You can find several free resources on the internet for welding operations and what is contained in them, however, @metengr defined it pretty well in his response. Hope this helps.
