Selection of Boiler super heater tube temperature for creep.
Hi all,
I am a little bit confused on the selection of super heater tube temperature to identify whether the tube is operating above or below the creep threshold temperature values. Should I use the steam temperature or flue gas temperature for the creep threshold value? If I take the replica at the outer diameter surface, should I use the flue gas temperature or inner steam temperature as the tube temperature? If we not have information on metal temperature of the tube because we did not have thermocouple attached to it which temperature can I used for the estimation of tube temperature?
Any comment is highly appreciated.
RE: Selection of Boiler super heater tube temperature for creep.
You can refer to European Boiler standard EN 12952-3. You can find there so called temperature allowances. They set different temperature allowance for different boiler component and
heating mechanism. For example for tubes with superheated steam heated mainly by radiation temperature allowance is 50 deg C. This allowance shall be added to reference temperature which is basically steam temperature.
Transient events can cause a short term overheat much hotter than the full load case descried above. For example, a typical US coal fired boiler does not have a steam to reheater bypass system, so if the unit experiences a MFT at full load there is a 12 second period for which zero steam is flowing thru the reheater tubes yet they are exposed to full load fluegas temperatures. Overheat above the first critical temperature might occur, but severe ID oxidation does always occur with each MFT. Similar overheats occur to reheaters during "fast valving" of the IP intercept valves.
Additional overheat creep damage occurs if there is a significant accumulation of oxides or scale in the inside of the tubes. These accumulations insulate the tube metal from the cooling effect of the flowing steam, and the resulting tube metal temperature can be much higher than the original design's clean assumption.
