CSI SAFE_2016.v16.0.0 * * * E R R O R * * * (WHILE RUNNING ANALYSIS) BAD FUNCTION DATA
Dear All
i got an error message as follow [CSI SAFE_2016.v16.0.0 * * * E R R O R * * * (WHILE RUNNING ANALYSIS) BAD FUNCTION DATA]
also the program does not read any envelope loads combination in results.
I got an extra steel on the raft less than normal.
Can any one advise how to solve this issue.
i read some topic, it is refers to an error in reading the spectrum load from etabs to safe, bearing in mind that we are using etabsv2016 as-well
RE: CSI SAFE_2016.v16.0.0 * * * E R R O R * * * (WHILE RUNNING ANALYSIS) BAD FUNCTION DATA
Thaidavid
