Please help at which point the pump will works ?
Hey , in the image i uploaded if we have a pump and its pump curve as shown , the pump is a single speed pump so its only one H-Q curve ,,, If our system required flow and head is at point 1 so at what point it will intersect the pump curve and also if our system required flow and head is at point 2 this is beyond pump curve pump but also the pump will work at which point exactly ?
RE: Please help at which point the pump will works ?
By using a control valve you can get any flow at any head which is under the curve.
Point 2 is not possible.
